/** Prevent extrusions longer then x mm for one command. This is especially important if you abort a print. Then the
extrusion position might be at any value like 23344. If you then have an G1 E-2 it will roll back 23 meter! */
#define EXTRUDE_MAXLENGTH 100
setting the limit for a single E move. This is to protect for a common error users make. Imagine print stopped at E4992 and user sends
G1 E0
That would retract nearly 5m of filament.
