ADVI3 FW, printer display shows IPv6 while idle, Sebatian from ADVI says its from Repetier
Is this true? Does the source of this data at the very bottom of the screen while idle come from repetier? I could not find any way to modify this, change to ipv4 or any reference to this in the repetier docs. I don't think that is the case but I could be wrong. I know repetier injects info into gcode while printing but I didn't think it could modify the display at idle.
Can you send manually
@getip
and see what it then writes. My guess is that wlan wasn't up when it send the ip so it used the ipv6 from eth0.Dave
Dave
