inductive sensors on 5v
How are the vast majority of inductive auto-levelling sensors intended to be used if they're 6-36v? My MKS Base and many other motherboards only supply up to 5v. Is there something i'm missing? Is there any way to get them working?
  • Main voltage is normally 12V or 24V so you can use that. You only have to take care of the signal pin that it delivers voltage at right level. I know you can put any voltage down to 5V with resistors, but check internet on how to do this.
