Debugging
I am trying to verify the operation of the printer. I would like to just be able to individually move the x y and Z axis. But I can't figure out how to do this. I think that the heat bed and the extruder are not heating but I will worry about that after I get the basic motion working. Right now I can't seem to do anything. Whenever I try to manually send a command to move the steppers I get an error that says use M999 to reset and talks about a temperature reset. The console seems to think that the extruder is at 480 degrees centigrade even though it is off, and cold to the touch.
