Autoleveling used for PCB milling
Hello I try to use the Autoleveling for corrting the PCD level he do not work.
I will try to give you all the detail if somone can support me
I go to a position where I put a tool for the PCB
G1 X260 Y270 F1000
After I surch the 0 material
G30 P0 => give a value
G1 Z"the value" F100
After I put the Zero machine at this point "X260 Y270 Zxxxx"
G92 X0 Y0 Z0
I go up 1mm and start a heigt map in the tool with a matrix
Xmin 0
Ymin 0
Xmax 85
Ymax 50
X point 8
Y point 5
It give me this matrix
X: 0,00 12,14 24,29 36,43 48,57 60,71 72,86 85,00
y: 50,00 100,42 100,38 100,38 100,39 100,40 100,42 100,43 100,43
y: 37,50 100,42 100,40 100,39 100,40 100,40 100,41 100,43 100,42
y: 25,00 100,42 100,40 100,39 100,40 100,40 100,41 100,42 100,42
y: 12,50 100,43 100,40 100,38 100,39 100,39 100,41 100,44 100,45
y: 0,00 100,42 100,39 100,37 100,37 100,37 100,40 100,45 100,50
so after I want to correct with G32 but
When I enter the Gcode:
M557 X0:85 Y0:50 S10
an error is comming out
01:03:51.819 : N5 M557 X0 Y0 S10*82
01:03:51.819 : Unknown command:N5 M557 X0.00 Y0.00 S10
If I enter G32 the leveling start from the homing of the CNC and not from the G92 X0 Y0 Z 0 that I deffined
I have see that: "RepRapFirmware executes macro file
bed.g
if present instead of using the M557 coordinates."How it works ????
Please
can you help me to enter the correction using G33 S0 or S1 (I do not
want to store it in the EEPROM or maybe if there is a good reason for)
My frimware configuration is
![Image: https://forum.repetier.com/uploads/editor/2n/39vj8m4rdzjd.jpg](https://forum.repetier.com/uploads/editor/2n/39vj8m4rdzjd.jpg)
![Image: https://forum.repetier.com/uploads/editor/32/h26r1alltwom.jpg](https://forum.repetier.com/uploads/editor/32/h26r1alltwom.jpg)
Regards
Thierry
