scara printring problem
I am making SCARA single arm 3D printer now.
The firmware is using WANGSAMAS, and all the fabrication is completed and the test is running.
The problem is that, even though I have finished the calibration, every time print an object, the object becomes distortion.
For example, When a rectangle is output, it is shaped like a rhombus.
I see this problem as a problem that occurs when the bed is rotated.
I wonder if the WANGSAMAS firmware can fix this problem.
  • Why do you now ask here. This is repetier-firmware. We have no idea about wangsamas firmware here. I hope they have a own forum somewhere.
