HEATING IS OFF FROM SETTING
I have tested the heating in the extruder and works ok,
However I have tested actual temperatures against the set ones.
I have used a good electronic thermometer.
The bed will not reach 55 but will hover to 45. The system would think the temperature is 55.
My thermometer shows a reading of around 45 degrees C
The extruder when set to 255 will reach only 230-235 and the display shows it is 255 while the actual temperature would be, according to my thermometer, 230-235.
I have type 1 sensors in the firmware...
Thanks for any leads.
