I have just downloaded version 2.1.3, but it have a problem running: it show me that it search translation files ". <filename>.xml" but file is named "<filename>.xml".
For example it search ". it.xml" but filename is "it.xml".
I checked linux 2.1.3 version and there are no .it.xml files. At least in 2.1.3. They can in deed cause a problem so delete them if you have any. Might be from a older install.
Sorry for the delay
This is one of the message I get when I try to launch RH:
The directory is fully what I have downloaded, with the only exception of the bash file that I have modified to the right path of my disk.
Strange thing. I had made this with my mac so the mac has added these files causing the error. I have reuploaded a new version without these files, but you need to delete the data folder before reinstalling.
Or you sinmply remove the ._ files in data/translations then it should also work.
I had the same problem as described by Lemming and removed all of the ._*.xml files in the data/translations folder. Now the splash screen come up with no error and for a second I can see the full app window but then it shuts down.
# Use your path to program directory
MYDIR="/HDisk/lem/dati/RepetierHost/"
cd $MYDIR
mono RepetierHost.exe -home "$MYDIR"&
What do you want to achieve with the -home option that does not exist? Every user has already it's own work directory and change it in host.
