ETA Wrong
Hi, I just like to say that I'm very grateful for your software and a huge fan. I'm experiencing a problem with the ETA for my prints which is drastically wrong both within Repetier Host and Repetier Server. I'm using Repetier Host version 2.1.2 and built in Curu to slice my model, with a print speed of 60mm/sec. An ETA of 1 hour actually is about 5 hours. The ETA reported in Repetier Host is the same as the ETA reported in Repetier server which is running on a Raspberry Pi.
My Configuration:
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 2
#define XAXIS_STEPS_PER_MM 320
#define YAXIS_STEPS_PER_MM 320
#define ZAXIS_STEPS_PER_MM 1517
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 187
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 170
#define Y_MAX_LENGTH 130
#define Z_MAX_LENGTH 196
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 10
#define DISTORTION_LIMIT_TO 5
#define DISTORTION_START_DEGRADE 50
#define DISTORTION_END_HEIGHT 50
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 160
#define DISTORTION_YMAX 120
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 100
#define MAX_FEEDRATE_Y 100
#define MAX_FEEDRATE_Z 50
#define HOMING_FEEDRATE_X 20
#define HOMING_FEEDRATE_Y 20
#define HOMING_FEEDRATE_Z 20
#define HOMING_ORDER HOME_ORDER_ZYX
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define ENABLE_BACKLASH_COMPENSATION 1
#define X_BACKLASH 0.05
#define Y_BACKLASH 0.05
#define Z_BACKLASH 0.115
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 20
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 20
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 20
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 40
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 40
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 40
#define MAX_JERK 10
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z2_STEP_PIN ORIG_E0_STEP_PIN
#define Z2_DIR_PIN ORIG_E0_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E0_ENABLE_PIN
#define USE_ADVANCE 0
Kind Regards,
My Configuration:
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// Delta settings
#define MAX_JERK 10
Kind Regards,
These are acceleration so incredibly slow, I wonder that you like to print that way. 1000 is normally a slow acceleration so 20 is nothing. Z axis often goes down to 50, but that is all. Any reason for these low values? Anyhow, this is the reason for the big difference along with a low jerk requiring much acceleration. You can increase them in eeprom, no need to upload again.
Kind Regards,
