Save multiple bed distortion correction tables in EEPROM
Hi, most bed distortion correction tables / configs vary with different bed temperatures.
Why is it not possible to save a number of these in eeprom depending on bed temperature / material being printed.
Bed distortion varies with temperature, if the tables were saved in eeprom (only one slot available at the moment) then the appropriate one required could simply be loaded, instead of having to re-run bed distortion correction for other temperature before starting a print.
Thanks and regards
P.S. 3 slots would probably be enough for most users
60 deg.
90 deg.
110 deg.
Thanks and regards
60 deg.
90 deg.
110 deg.
There is a solution though. After measuring send G33 L0 and you get a list of commands you need to set the to the current distorion level in log. Save them as script and then you can switch by sending the script.
Loading of a script would be faster than re-doing bed distortion correction for every change in temperature.
I did a search but could not find any instructions on how this could be done, hoping you can assist.
I have Cartesian printer with:-
RUMBA board
Repetier v1.0.2
Octopi with raspberry Pi3
RepRapDiscount Full Graphic Smart Controller
Thanks - bruce
Of course we can also store multiple 5x5 grinds. But a grid of 22x22 will use all memory and no second or third matrix can be stored. I will see if add this in V2 firmware for smaller grids where multiple grids fit.
Thanks again and regards
