lower speed limit
Good morning, we are using and Arduino card for controlling the program and we need to operate at < 2 mm/s X-horizontal direction, but the minimum speed that we can achieve is 5 mm/s.
We have tried changing feed rate eg F100, F150 and the speed is the same, but if we put F2000 the motors go faster.
How can we change this value, is there a speed limit?
The next big firmware version V2 will have a different timing caclulation and therefore have no speedlimit any more.
By the way, Do you know when the new version is going to be available?
Thanks again
