Axis movement is not as displayed in Host
I am new to this 3D printing, and recently I have built a small machine, Machine was tested with placing a pen to check the distance movement of X Y Z axis. If I 10mm in Repetier host, The bed is moving exactly 5mm, I checked for multiple pulse per mm configuration, and am using a unipolar steeper motor with bipolar drive,
  • Host just sends a 10mm move command to fimrware which executes it. Double steps per mm in eeprom editor and test again.
