FAN reverse default value
when I boot up the Repetier firmware, I would like to have the FAN speed running to 100% instead of 0%
I won't extend the explanation as it's quite complex, but the goal is to switch off my laser which is connected to D9 when I switch on my CNC.
thanks in advance !
  • You can set fan speed in the startup script quite early. If you need it even earlier, you have to write the initialization for this on your own.
