Printer starts to print but stops
I can slice and print in Ponterface and Slice and print in Cura but I can only slice in Repetier when I print it will only home and move to the beginning of the print or maybe a line or 2 then stop. Sometimes a timeout error but mostly it just freezes and I have to shut down through task manager.  I can also slice in repetier and import gcode to ponterface and cura and it prints just fine. Not sure if i have a setting wrong in repetier or not. I am running a MKS makerboard V1.3 with smoothie firmware.
  • Did you set in Printer Settings->Printer firmware type to Smoothieware? This is important for correct error handling. Also have a look at the log (disable easy mode to see it). It might give more information on what goes wrong.
