Upgrade to Server 0.86 changes time estimates
in Bug Reports
I have had some problems upgrading both Repetier Server and Repetier Firmware. This is regarding Repetier Server 0.86.
The machine is a D-Bot (CORE-XY) derivative with 3 Z motors and a BL-Touch probe, electronics are Due and RADDS, and a Raspberry Pi for Server. The bed is not very flat. but I have had very good results using Repetier-Server 0.80 and Repetier-Firmware 0.96 for over a year (thank you!).
I replaced Server version 0.80 with the latest 0.86 using the armel package, leaving the existing printer config and G-code files alone. To my surprise, the new Server seemed to be re-loading (or something) the existing G-code files. It was very slow, but the problem I noticed was that it changed the time estimates to be extremely large. For example, 187 hours rather than 6 hours (about).
I ended up using a new image instead due to other problems, so I can't say whether this affected printing, but it was odd. Using the 0.86 image for the Pi, the times look OK.
A change from 6 to 187 hours is not good.No idea why that should change so dramatically. You should check in printer settings if the acceleration or max. speed for an axis or extruder is wrong/low, preheat time. Changing these values starts again recalculation of times. If you find no error, please send me the gcode so I can have a look at the gcode to see why it gives such a wrong estimate then.
I was about to say that I have uploaded some files into the new version of Server, and that had reasonably accurate estimates. However, I just took a another look and I see that a test piece that I printed since the new Server was installed, and which was estimated at 24 mins and actually took 20 minutes, is now estimated at 181 minutes!
Setting the heating time rates in the printer config fixed the estimates. I must not have reloaded the printer settings from the saved XML configuration when I loaded the new Server, as I intended. My mistake. However, it still leaves open the original question of why the heating time config was lost when I first did the upgrade: I am sure I did not do anything to the printer config when I upgraded, though I had upgraded the firmware to 1.0.2 first - could that be related? My memory is of seeing the time estimates change before my eyes, so they were OK before the Server upgrade.
