Change A4988 stepper driver by DRV8825 ones.
I built my own 3d printer and it works fine. I use the Prusa as a model.
Now I have a simple problem, but that I am not able to solve.
Sorry for the noob question, but in "Configuration.h", which lines should I edit to change the A4988 stepdrivers I got in X and Y axes to the new ones, DRV8825?
Are there any changes to be made to eeprom as well?Thanks!!
The DRV8825s with the 3 micro stepping jumpers fitted will have 1/32 microstepping so you will need to double your steps/mm in config or eeprom.
