Zmax 2 endstop and mirror moter output to motor driver
I m curious what the implementation of the second end stop is and mirroring the z motor signals, since the z axis has two outputs on the ramps board, does this allow each side of the z gantry to be controlled? as in the z max 1 end stop affects motor 1 and z max 2 end stop affects motor 2? This would be nice since sometimes the second side will go up further than the other since only one side has a limit switch
  • Yes, it is to adjust both sides when homing. But it can not use the dual connector z pins. You need a separate driver for each axis then, otherwise it is physically not possible to just start/stop one motor.
