Host crashing on connect to printer (windows 10)
Hello I have been having some issues with my Tevo tarantula 3d printer when using it with Repetier Host. The issue seems to be a connection one. Repetier host freezes when the connect button is pressed locking up entirely requiring the process to be ended. I have reinstalled Repitier twice, tried three different cables. No visible errors seem to be created and the software just seems to lock up.
I'm entirely out of ideas at this point so any help is much appreciated!
Many thanks.
Locking up on connect normally switches to not available or already in use error after a short while.
In the devices tab on the PC which crashes Repetier (windows 10), it appears that the printer hasn't been given a com port and appears as a "Unknown USB Device (Device Descriptor Request Failed)". Where as on the PC it can connect to (Windows 8) it appears as a Com port.
What firmware are you using? And what printer board do you use?
