Extruder won't extrude but is ticking?
Hi Guys,
I got almost anything up and running but there is one last thing which won't work.
The extruder is ticking but it isn't actually extruding.
It did work before, hotend is at the right temperature and it is responding to the commands giving (except it isn't extruding)
My source code:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
generator: http://www.repetier.com/firmware/v092/
as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#define FAN_BOARD_PIN -1
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 640
#define YAXIS_STEPS_PER_MM 640
#define ZAXIS_STEPS_PER_MM 3200
#define PDM_FOR_EXTRUDER 1
#define PDM_FOR_COOLER 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
// #################### EXTRUDER 0 ####################
#define EXT0_X_OFFSET -18
#define EXT0_Y_OFFSET -18
#define EXT0_Z_OFFSET -18
#define EXT0_STEPS_PER_MM 784
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 1 //for RAPS128
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_PGAIN_OR_DEAD_TIME 5
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 240
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
#define EXT0_DECOUPLE_TEST_PERIOD 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
// #################### EXTRUDER 1 ####################
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 784
#define EXT1_TEMPSENSOR_TYPE 8
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN //PIN SETUP
#define EXT1_HEATER_PIN HEATER_2_PIN // PIN SETUP
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN E1_ENABLE_PIN
#define EXT1_ENABLE_ON 1 //for RAPS128
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_PGAIN_OR_DEAD_TIME 5
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 240
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
#define EXT1_DECOUPLE_TEST_PERIOD 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 1.9
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_X_POS 10
#define FILAMENTCHANGE_Y_POS 10
#define FILAMENTCHANGE_Z_ADD 10
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define RETRACT_DURING_HEATUP false
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define USE_GENERIC_THERMISTORTABLE_1
#define GENERIC_THERM1_T0 25
#define GENERIC_THERM1_R0 100000
#define GENERIC_THERM1_BETA 3950
#define GENERIC_THERM1_MIN_TEMP -20
#define GENERIC_THERM1_MAX_TEMP 300
#define GENERIC_THERM1_R1 0
#define GENERIC_THERM1_R2 10000
#define GENERIC_THERM_VREF 3.3
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 100
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEAT_MANAGER 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 7
#define HEATED_BED_DECOUPLE_TEST_PERIOD 0
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 280
#define MIN_DEFECT_TEMPERATURE 5
#define ENDSTOP_PULLUP_X_MIN false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 180
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// ## Movement settings ##
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 900L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 20
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 10
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0 //?
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 80000
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
#define MAX_JERK 10
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#define PS_ON_PIN -1
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 1
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 1
#define FEATURE_WATCHDOG 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#define SDCARDDETECT ORIG_SDCARDDETECT
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 7
#define UI_LANGUAGE 0
#define UI_PRINTER_NAME "Duplicator I3"
#define UI_PRINTER_COMPANY "James / Jetguy"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 90
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 220
#define UI_SET_MAX_HEATED_BED_TEMP 110
#define UI_SET_MAX_EXTRUDER_TEMP 240
#define NUM_MOTOR_DRIVERS 0
![](https://img.youtube.com/vi/2ER3nTLyvrk/0.jpg)
My source code:
as you expect.
#include "pins.h"
#define MAXTEMP 280
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// Delta settings
#define MAX_JERK 10
#define SDSUPPORT 1
#endif
Before it worked, so this is really weird.
G92 E0
G1 E30 F60
will extrude at 1mm/s for 30 seconds. That is slow.
It might also be a broken wire instead of contact. Or stepper driver is defect. You can find this easily by swapping components e.g. x motor on E axis to test if e driver is ok. And E motor on X axis to test wires/motor.
Turning the settings you gave = also no luck
I don't understand because it has worked before
What microstepping?
You have some large numbers in your config regarding steps/mm and max feedrate, maybe try reducing the max E feedrate see if any different.
What do you advise?
So motor/cable then look good.
> When attaching Extruder to X it worked but still the ticking.
Confusing statement. I thought the ticking was the error, so how can it work then?
Do you have a second extruder stepper driver so you can swap the 2 drivers. Or connect Extruder to second extruder second and configure firmware to use that. From your description so far the driver or a connection on board might be defect. Or the current is that low that motors can not turn, but you said vref is already adjusted.
> Extruder went on X and turned quite well, but is ticking
Maybe, the cable is not soldered good enough I am going to redo that to be absolutly sure it can't be a cable defect.
> When attaching Extruder to X it worked like a charm!.
No ticking, no strange sounds all worked great.
I do have a two extruders, so I've got two drivers. Both are ticking which may come from the fact they arent moving (but try to move)
Now I am thinking about it:
When only one heater was attached, the extruder worked like a champ! The problem occured when I attached the second heater... SO maybe after all it could be a power issue.
My V-ref is on a 1.60V for both stepper drivers.
How High can I go before messing that stuff up? (maybe it doesn't get enough juice, when screwing the V-ref back to 0.30 to 0.90 it doesn't even make a sound nor movement)
Sorry but my native language is Netherlands.
With the motors rocking back and forth i would suspect either coil pairs wired wrongly(A-B C-D) or a broken wire.
