You have to take care of that yourself. That is why I said position it left and not center. Where an dhow wide it can get depends on firmware and settings I think.
Are there any negative x moves in your gcode? You could test manually what range is achieveable and as long as you keep inside that area printing should not hit the endstop. Normally you start at x min and can move 50% of width to the right.
