can i do small test moves from skeleton machine?
Should I be able to make small movements on the nema motors after flashing with a fairly generic config? Or is there some kind of safety constraint that entirely prevents motor movement until a home is done, or some other requirement?
I'm setting up a new machine, and only testing things one at a time as i plug them in. I cannot make the XY axis move in order to test if i have the right ballpark or now.
Also, in this forum; why does shift-ctrl jump to the start/end of the line instead of the next word? That's incredibly annoying.
With only X and Y nemas plugged in (nothing else aside from 2x12v power and USB), corexy architecture specified, endstops in their default off-unless-homing type behaviour and not even plugged in... i should be able to tell the printhead to move +x 1mm or +y 1mm when connected via repetier host.
And yet I cannot. Strange.
