import G-code and convert to stl file
I'm interested in a feature where you can import a G-code file and save the 3D model visualization as a stl file. Is this possible? If it's not, what is the data structure behind the 3d visualized model? Thank you!
  • No it is not possible, only the other way around. The aims of the format are completely different. STL is a boundary representation and gcode is the machine control language to approximate the shape with given constraints and options.
