Configuring Extruder MAX Feedrate, Start Feedrate, and Acceleration
What is the procedure to configure these settings so that I get the most speed out of my feeder without inducing skipping/grinding of filament.
I am using .85A .9 degree Steppers that output 59 oz-in (0.42 N-m) holding torque. They are ran by a TMC2100 stepper driver with the POTS configured to provided the OEM specified amount of power for the motor, not more and not less.
Currently my Repetier firmware settings are:
MAX FEEDRATE: 35 mm/s
START FEEDRATE: 5 mm/s
ACCELERATION: 3000 mm/s
I am getting some issues with skipping and grinding what should I adjust?
Extr. Start Feedrate: 5.000 mm/s
Extr. Acceleration: 3000 mm/s
Retraction Speed: 55mm/s
X-axis max. feedrate: 250.000 mm/s
Y-axis max. feedrate: 250.00 mm/s
X-axis acceleration 1000.000 mm/s
Y-axis acceleration 1000.000 mm/s
I am not sure if I didn't specify my settings correctly so you would understand my situation. So what your saying is set my Extr. Start Feedrate at 3.000 mm/s and adjust my Extr. Max Feedrate based on how fast I want my retraction to be, so if I want to set my Retraction Speed to 55mm/s I need to make sure not to restrict it with the Extr. Max Feedrate? So I should turn the Extr. Max Feedrate: 55mm/s so that my Retraction will truly run at 55mm/s ?
Thanks for the help. Also any other comments or advice you might have are very much welcome.
