Z Probe Home XY Strange behaviour
Hi, I have been trying to setup software correction autolevel on a i3 clone using v1.0.1 firmware for some time and its driving me mad.
I have install an inductive probe 56mm behind my x carriage and am setting up the Z home first and when I set the probes offset to 56 and the zhome_y_pos to zero I get the fatal error saying -56 is invalid.
That seems correct (as the bed can't move -56 to position the probe at zero) but when I set the home to 56 (essentially 0) it moves the bed 56 so the probe is at 112 while it takes the reading then moves back to zero??
Am I confused or is something strange happening??
What does that mean in settings?
y home should still be 0, you just need to tell homing to probe at y=56 so it can make the move (or probe at 80). Select homing order with preheat so you can set where to probe z, set preheat temperature to 0 as you do not need that.
You can delete this post.
thanks
When homing, it probes (extruder @ 0 & probe @ 56) but then moves the bed (extruder @ 56 & probe @ 112) for the second probing which i guess is the "Reduction factor 2nd test".
It moves back to the correct position after though.
Autolevel is also working.
