What are low PID values?
The Repetier FW configuration tool recommends to use Scale PID values to max. PID. Can give better temp. results if max. PID is low. (SCALE_PID_TO_MAX).
But what are "low PID values"?
Here are mine (100k NTC 3950, Extruder): Kp: 7.24, Ki: 0.15, Kd: 26.02
  • You do not want this normally. This is for use with wrongly dimensioned heaters, e.g. 12V heater used on 24V so max pid value is 64 instead of 255. It has nothing to to do with K, P , D values.
  • Thanks for explanation.
