Running it on Orange Pi One Plus ?
Hi
Did someone try to run Repetier Server on an Orange Pi One Plus (http://www.orangepi.org/OrangePiOneplus/) ?? It's pretty similar with Raspberry Pi with more powerful processor !
If not I'm ok to test it but just not sure which architecture I should select for download of Repetier Server ?
Vincèn
If you want to use the pro version make sure ethernet always gets same mac address. I think it was the orange pi that liked to change mac addresses after reboot.
I have imported my printer settings and I expected to have just the USB port to adjust. Unhappy whatever port I select, connection status sort of blink (red most of time and sometimes goes briefly yellow and then comes back at red !). It offers me some tty, up to tty63, ttyS0,ttyS1,ttyS3 and ttyGS0. I have tried all of them out of the tty with numbers but none of them work ! Any ideas ?
You can call ls /dev/tty* with and without printer connected. The one that disappears is the port you search.
I know some linux kernels have no serial driver support compiled in. If that is the case with the orange pi linux, then you have a problem. You need to recompile it or find a linux distribution with serial support that works on orange pi.
Will investigate if there is a way to get it working with an other distro (not much choice for now for the One plus) or recompile it with support of it !
