Scaling in Negative #'s?
Maybe I've got a wonky install or something, but did Repetier 1.0.4 remove the ability to scale a print in the negative? I used to use a -1 scale on the y axis to make mirrored prints. I don't appear to be able to do that now.
  • Yes that is correct. Scaling with negative values would change normal orientation and triangle orientation. That is why nagtive values are not allowed. None the less I agree that mirroring would be a good function to have. Will see, that we include it in one of the next versions.
