fails to load .stl files
I have used Repetier Host without a problem for a year and a half. Today, it will not load .stl files. The message says that it is loading, but the file does not appear. It will load g-code files, however, and there are a few .stil files that will load, but mostly will not. Is this a bug? Or is it a mistake? I have checked to make sure Updates are current. I have V2.0.5, running on Windows 7Pro.
Did yo already reboot windows? Also make sure no other software has stl opened as that will block opening it.
It used to work just fine. I would export the Meshmixer file, and it would put up a screen that creation of the .stl file. Then, Repetier would import the .stl and allow generation of the g-code. But now, when Repetier is ordered to Load, the only screen that comes up is Import G-Code (not .stl).
I am spinning my wheels going around and around. What am I missing?
file opens in SolidWorks, Blender 2.8 ** and 3dMax
If it is rather small please provide a download of the stl so I can check if the header is wrong.
