Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
General
Let’s Encrypt / Trusted SSL
shawnrw
April 2018
in
General
Anybody had any luck getting Let’s Encrypt to work with Repeater Server? I cannot the certificate system to grab the cert as both need port 80.
Regards,
Shawn
Repetier
April 2018
Server does not use port 80. Nginx is on port 80 and certbot knows how to handle this if you say it should use the server. Bigger problem is that you need to be reachable under a domain with the set ip.
Sign In
or
Register
to comment.
