Copy from Log view works strange
When an object is loaded into "Object Placement->3d View" - Ctrl+C\Ctrl+Ins doesn't work properly in Log view. It looks like Log view continuosly lose focus.
But with empty 3d view log works as expected
  • Mh, always used the copy button and had no problem. But you are right without object I can also use Ctrl+C and not when stl is loaded. Need to investigate this.
