Plugin for Inkscape 0.92 inside-contour
Hi all.
Plugin for Inkscape 0.92, tell me while working, first executes the circuit then the middle, where it is possible to change the code in the code, so that it would first work out the details inside and at the end the contour? I use it both for a laser cutter, and during work the piece is cut and falls (in Python it is not strong.
