Nozzle Crashs into Bed
I have a Da Vinci Duo 2.0A which I have flashed with Repetier. On the laptop, I use Windows7 Repetier to control the printer.
The automatic calibration I have run which has led to a good result. All three values are almost identical (Z1: - 6.079 mm, Z2: - 6.089 mm, Z3: - 6.084 mm).
If I click on Home in Repetier, then the head moves to the far right and front. The print bed starts up. The printhead is next to the print bed. The print bed is higher from the nozzles.
If I drive manually over Repetier the bed down and position the nozzles over the bed to carefully drive up again. Repetier shows a value of 1.50mm if I can just push a business card in between.
Where do I have to enter the correction value?
If I manually start the G-code I wrote for the start (heating up and trial printing), the nozzle collides with the print bed.
Best regards
Tibercad
Best regards
Tibercad
In the eeprom settings in the printer: Xmin pos = 0, Ymin pos = 0, Z min pos = 0. Xmax length = 201, Ymax length = 204, Zmax length = 201.
Where is something to enter now? I'm just a bit confused.
Is it normal for him to go to absolute 0 via the home button?
If printer homes to min (nozzle touches bed) you need to calibrate min endstop to stop at right place. For max as I said change z length in eeprom and set same value to z home in host.
http://www.bilder-upload.eu/show.php?file=8bc90b-1523109238.jpg
I start Repetier host, connect with the printer and click again on the Home Button, then I have the following in the display.
http://www.bilder-upload.eu/show.php?file=bef8f6-1523110621.jpg
My values currently in the eeprom from the printer are as follows (from yersterday):
http://www.bilder-upload.eu/show.php?file=0bdeae-1523109558.jpg
If I set ZMin to 0 or even 1.6mm then the printer still drives the table too high so that the nozzles are deeper than the bed.
If I manually drive the bed 1mm down, then Z jumps from -1.60 to 0. The printer does not drive down the one millimeter but so that it is in the allowed range. Nozzle and bed then has the correct distance.
Do I have to drive down the bed 1.6mm in the start code at the beginning? How can I tell the printer that from 0 applies?
Sorrey i have tryed to put the Pictures as link, but the Preview shows me nothing.
If that is position after homing (touching bed) you home to z min and your z min endstop just ttriggers 1.6mm to late and you have to recalibrate that it gets activated earlier. That is all. Never let homing first crush into bed and then relax. Also that is possible it will sooner or later damage something. You can for this reason adjust endstops or tighten bed screws so bed goes down 1.6mm more. This is then a hardware problem that needs to be fixed in hardware.
