Z offset not working in ver101 will not go below zero
Using ver0.92.9 I would run
g28 x0 y0
g0 x110 y110
g28 z0
then I would move the extruder down to set the extruder height usually -1.12
then I would set the z offset to the value I needed and i could print.
With ver 101 I cant do that. The extruder will not move below 0. when I set the offset in the firmware the extruder will not approach the bed and stays above the bed at zero.
Am I missing anything. I have check endstops off.
I liked the function to set it using the LCD because I could raise it a bit for the PETG when I needed it.
Thanks for any help
g28 x0 y0
g0 x110 y110
g28 z0
Thanks for any help
G1 S1
to disable target position testing, which is what prevents the move I think.
