Bad Bed-leveling/Z correction
Hello, I have a question:
(I have repetier v1.0.1) When I use the G32 S2 for leveling, everything will work fine. The correction works well, but if the extruder goes to Y> 90, the Z axis will begin to rise a lot. About two millimeters rises. But the bed map does not answer that. Why is it?
There is my configuration:
And there is my eeprom:
And there is my bed map:
#define Z_PROBE_Z_OFFSET 1.1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 1.16
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 56
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 4
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 1.95
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "G1 Z3 F500"
#define FEATURE_AUTOLEVEL 1
#define FEATURE_SOFTWARE_LEVELING 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 150
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 165
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
13:22:26.123 : Z correction disabled
13:22:26.123 : Info:Autoleveling disabled
13:22:32.401 : Z-probe:5.261 X:56.00 Y:0.00
13:22:39.226 : Z-probe:5.264 X:56.00 Y:72.50
13:22:46.070 : Z-probe:5.290 X:56.00 Y:145.00
13:22:54.602 : Z-probe:5.179 X:123.00 Y:0.00
13:23:01.385 : Z-probe:5.160 X:123.00 Y:72.50
13:23:08.169 : Z-probe:5.162 X:123.00 Y:145.00
13:23:16.717 : Z-probe:5.219 X:190.00 Y:0.00
13:23:23.529 : Z-probe:5.232 X:190.00 Y:72.50
13:23:30.492 : Z-probe:5.202 X:190.00 Y:145.00
13:23:30.496 : plane: a = -0.0004 b = -0.0000 c = 5.2692
13:23:30.505 : Transformation matrix: 1.000000 0.000000 0.000402 -0.000000 1.000000 0.000013 -0.000402 -0.000013 1.000000
13:23:30.505 : CurrentZ:5.27 atZ:5.28
13:23:30.508 : Info:Autoleveling enabled
13:23:31.348 : X:190.00 Y:145.00 Z:5.189 E:0.0000
13:23:31.348 : Z correction enabled
M323 S0 P1
to see if it comes from that.
