Bed Height Map Probing Only One Spot
When I try to run the bed height map tool, it only probes one spot over and over.
What is causing that? It should be checking the specified grid.
  • First check set rectangle coordinates. Then also check log output for error messages that might give you a hint like probing outside allowed region.
