Heat extruder works only with command line
Hi !
I have a problem with Repetier-Host that I don't understand.
When I click on "Print"; it is indicated "Heat extruder". But the temperature doesn't increase. I don't understand because when I type the command line, the extruder heats up and I see the temperature rise. Except that even when the temperature reaches 250 (or 210) degrees Celsius, printing does not start.
Any idea ? Where do the problems come from ?
Best regards
Best regards
Your description does not match pictures. Last picture shows ETE but temperature is reached, which is what you say does not work.
An other thing is the M109 will wait inside firmware until firmware thinks the target temp. is reached. If that does not happen, print will not continue. Can happen if you say temp. must be within 0.5°C for 10 seconds or something like this you can not reach due to swinging temperatures.
