Teknic servo + Repetier Firmware + Mega 2560+Ramps 1.3
Hi all I'm trying to use Teknic servo SD ,arduino mega 2560 with ramps with repetier firmware.
Do I need to make changes in my configuration h. file to run the servo motor? If so what changes do I need to make?
I've tested out the motor with Arduino Uno board and worked perfectly fine, this is without repetier, so I assume that this is configuration issue.
Help me please!
These things are powerful if provided with good power. Teknic's power supply is pricey but guaranteed to work. 24V is the bare minimum but I would recommend at least 48V.
Good Luck.
