Filament Spool Manager
I just started using the Repetier Server today, and so far I'm loving it. Will be giving the trial a good run over the weekend and decide if it is worth the 60 euros. But i have one suggestion for it that would make my life easier. I have multiple reels of filament, sometimes of the same colour, becuase I start a new one if I think the current one doesn't have enough for the print. Nothing like running out, while you're sleeping, on a 10+ hour print. What would be my idea, when a print job is started, the user would be asked which reel is being used. Better yet, on the filament load/unload page, that info could be entered. If the database thinks there is not enough filament left, it warns the user. Could even have it pause when it get near a set amount left.
Just my idea to make, what looks like a great piece of software, better.
I could see how having multiple spools shared between machines could be a problem. Almost need a central server on the internet or one computer designated as a server on the local network.
What really holds me with Octoprint is currently this functionality.
Any set plan if/when will be introduced?
It also have multiple instances possibility, but you need to set external postgresql database and connect all octoprints to it.
Setting external functional postgresql is however not piece of cake and I was not able to make it work.
But having at least the basics is really great.
