How to configure extension board steppers on RADDS
Hi. I am building a large format printer with 3 stepper motors controlling the bed height (Z axis) and 2 extruders.
I am using RADDS with the extension board.
I need to know which two stepper drivers I should attach the additional two Z stepper motors to (physically which pins) and how to setup the firmware so the 3 motors are controlled correctly. In the schematic, there are a variety of pin numbers for the extension board. Does one of those numbers correspond to the pins definitions? Is there already a label in the firmware for the two extra drivers? I guess I'm trying to determine which set of drivers pins is which...
Some help with this would be most appreciated!
Thank you,
Bryan
Thank you,
Bryan
