BL Touch Z-Probing Issues
I have a BL touch I am trying to get running on my Stacker S4 and it is not working properly. I can send gcode to it properly (the M340 commands work fine). When I home z though, if the pin is not already down, it doesn't go down and the probe doesn't work. Here is my configuration.h
#define ENDSTOP_Z_MIN_INVERTING false //--------------------------------------------EDITED from true
#define MIN_HARDWARE_ENDSTOP_Z true //--------------------------------------------EDITED from true
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 6
#define ENDSTOP_Y_BACK_MOVE 6
#define ENDSTOP_Z_BACK_MOVE 6
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 6
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0 //--------------------------------------------
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 510
#define Y_MAX_LENGTH 365
#define Z_MAX_LENGTH 650
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 80
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 15
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define ENABLE_BACKLASH_COMPENSATION 1
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH .1
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 800
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_JERK 15
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 24
#define MOVE_CACHE_LOW 10
#define FEATURE_DITTO_PRINTING 1
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 3
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 1 //--------------------------------------------EDITED
#define SERVO0_PIN 12 //--------------------------------------------EDITED
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 1 //--------------------------------------------EDITED from 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1 //--------------------------------------------EDITED from 0
#define Z_PROBE_BED_DISTANCE 7
#define Z_PROBE_PIN ORIG_Z_MIN_PIN //--------------------------------------------EDITED
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_START_SCRIPT "M340 P0 S700" //--------------------------------------------EDITED
#define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500" //--------------------------------------------EDITED
#define FEATURE_AUTOLEVEL 1 //--------------------------------------------EDITED from 0
#define Z_PROBE_X1 20 //--------------------------------------------EDITED
#define Z_PROBE_Y1 20 //--------------------------------------------EDITED
#define Z_PROBE_X2 40 //--------------------------------------------EDITED
#define Z_PROBE_Y2 20 //--------------------------------------------EDITED
#define Z_PROBE_X3 60 //--------------------------------------------EDITED
#define Z_PROBE_Y3 160 //--------------------------------------------EDITED
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
What exactly am I missing or doing wrong? The Z endstop that was replaced was the Z-min.
I have a working Prusa style printer with BLTouch on it.
Here is the Configuration.h known to work with this printer: https://raw.githubusercontent.com/alexsomesan/Repetier-Firmware/ramps-tmc2130/src/ArduinoAVR/Repetier/Configuration.h
Please have a look at that one and compare with yours. I will try to do the reverse and spot your problems when I get a bit of time.
Let me know if you spot them before.
Alex
I found a site to find the differences for us. Just copy and pasted.
https://www.diffchecker.com/diff ;
alot of differences. not sure what is important or not.
