could not activate Z probe error
edited January 2018 in Repetier-Firmware
i finally finished my new printer ready to go but I'm getting an error when bed leveling starts
could not activate Z probe offset due to coordinates constraints result is inaccurate
config as below
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 1
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 35
#define Z_PROBE_Y_OFFSET 5
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 10
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 200
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 190
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define UI_AUTORETURN_TO_MENU_AFTER 20000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN 11
  • Depends on which action it hapens - homing, G32 or G33. The used coordinates are not allowed with active t probe offset so you need to modify that position to lie inside allowed area.
  • G21        ;metric values
    G90        ;absolute positioning
    M82        ;set extruder to absolute mode
    M107       ;start with the fan off
    G28  ;move X/Y to min endstops
    G32 S2
    M82 ; use absolute distances for extrusion
    my bed is X = 275  and Y = 200 so its longest side is the X axis
    my config is attached in a zip file
  • edited January 2018
    from your config above, your probe is offset X 35 to the right of the nozzle and Y 5 behind the nozzle.
    So your minimum value for probe point X1 will be at least 35(i would go with 45)
    X2 can be upto 275 so maybe 265
    The other values should be ok.
    sorry for the delay in replying i was waiting for new materials for the new build but i am still getting the error
    i have attached the latest config i set it as 45 as told but still the same error
    #define Z_PROBE_Y_OFFSET 10
    #define Z_PROBE_X1 45
    #define Z_PROBE_Y1 10
    #define Z_PROBE_X2 265
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 45
    update i see this in the logs
    17:24:10.666 : Error:Activating z-probe would lead to forbidden xy position: -35.000000, 45.00
    If you changed the settings in the config.h  you will need to update the eeprom with a
    M502 ;read config
    M500 ;save to eeprom
    or just change the eeprom values using repetier host eeprom editor
