Custom retract routine with a servo
I'm using the latest firmeware version.
I use a syringe extruder on my Prusa. It works quite well, but there is too much elasticity in the system.
I want to implement e vacuum-based retract method. For that solution i need a drive e servo with the G10/G11 command.
Is it possible to modificate the retract routine in commands.cpp such i can control the servo.
Could this work?:
#if FEATURE_RETRACTION && NUM_EXTRUDER > 0
case 10: // G10 S<1 = long retract, 0 = short retract = default> retracts filament according to stored setting
HAL::servoMicroseconds(1, 500, 0)
case 11: // G11 S<1 = long retract, 0 = short retract = default> = Undo retraction according to stored setting
HAL::servoMicroseconds(1, 2500, 0)
#endif
break;
Thank you!
Could this work?:
#endif
break;
Thank you!
