Questions about dual X axis and Z2 end stop
If we got dual X axis,I think we should get two end stops for X axises , each for one axis,but I only found one,so how should we set up the end stop pin for both X axises?
And about the Z2 end stop,which looks pretty good,but since only one Z axis,ever though you can mirror it for both or three steppers,Z2 end stop seems useless,when the Z end stop is triggered ,all Z steppers will stop,so what's the Z2 end stop for?
Extruder x offset is the distance to x=0 so e0 has it positive to come out of it's box and E1 negative to go to same position.
In V1 you can use 2 z endstops to adjust on homing. Use Z2_MINMAX_PIN for second endstop. In firmware V2 we will get a different approach making it easier.
