M3D printer
Can an M3D printer be used with Repetier Host? I have tried to use mine and it connects ok but it doesn't heat the extruder.
  • What firmware does it use? Repetier-Host supports open source reprap firmwares like Repetier-Firmware, Marlin, Smoothieware. But smoothieware has some issues with multiple extruders as they handle extruders different.
  • It has its own proprietary software.
  • Then that might be the problem if it is not reprap compatible. Do they advertise it should work or do they want to force you using their solution? In first case your parameter might just be set wrong.
