Dual x steppers
Hello Everybody
I'm new here and hope I'm on the right section.
I have a problem with the Firmware repetier 1.0.0, i selected there dual x steppers (EXT1), but i cannot get the second motor to run, also swaping over to EXT0 is not helping, wiring and the drivers are OK.
Does somebody know this problem?
kind regards
Portex
  • Dual X stepper means extruder 0 uses first x stepper and extruder 1 second x stepper motor. I guess you wanted mirror x stepper so both turn the same time.
  • Yes exactly this i want to do.
    Is there a way to do this?
  • Yes, do what I said. Use mirror x and not dual x and it will work.
  • Thank you verry much, i haven't seen this setting first
