configuration tool for delta printer
you need no horizontal offset parameter because the deffinition of "horizontal radius when centered", "printer radius" and so on.
But there is no "printer radius" parameter in the configuration tool and without that the transformation shouldn't be solved.
So I watched in the Configuration.h and the "PRINTER_RADIUS" was defined with the same value as "ROD_RADIUS" (horizontal radius when centered) and the "END_EFFECTOR_HORIZONTAL_OFFSET" is 0, that means all rods will be connected to one point.
(Or may the picture above be not correct)
I think this is a different kinematic case and causes position deviations. If all my assumptions are correct should I adjust the "END_EFFECTOR_HORIZONTAL_OFFSET" or the "PRINTER_RADIUS" manualy in the Configuration.h to get the right kinematics?
I realy like Repetier and don't want anything else, so hope for your reply and thanks in advance
