issue with bed levelling
I tried to set up the autolevel as described in:
https://www.repetier.com/documentation/repetier-firmware/z-probing/ (with firmware 0.92.9)
;home
G0 X0 Y0
G0 Z0
;up
G1 Z15
;go to the middle
G1 X100 Y100
G30 P0
Recv: Z-probe:16.51 X:-1.09 Y:60.65  -> Z0 = 16.51
M114
Recv: X:40.00 Y:83.00 Z:15.000 E:10.0103 -> Zold = 15.0
Down till block fit nozzle -> ref height = 7.7
M114
Recv: X:40.00 Y:83.00 Z:6.700 E:10.0103 -> Znew = 6.7
ZHold = 6
ZHnew = ZHold - Z0 - Znew + Zold + ref_height
ZHnew = 6 - 16.51 - 6.7 + 15 + 7.7 = 5.49
Set new ZHeight in the EEprom
By starting my printing with the following code, I'm around 0.2mm higher (like the height of the first layer) as the plate:
######## STARTUP CODE
M140 S55 ; start heating the bed to 50 degrees Celsius
M104 S185;
G21        ;metric values
G90        ;absolute positioning
M82        ;set extruder to absolute mode
M106 S255  ;enable fan
G28 X0 Y0  ;move X/Y to min endstops
G28 Z0     ;move Z to min endstops
M190 S55 ; wait until the bed reaches 50 degrees before continuing
M109 S185;
G1 Z10.0
G32 S2      ;perform autobed levelling
G92 X50 Y-10 E0         ;zero the extruded length again
M106 S255;activate fan
;Put printing message on LCD screen
M117 Printing...
; Filament gcode
######## PRINTING CODE
M82 ; use absolute distances for extrusion
G92 E0
M106 S255
G1 E-1.00000 F1800.00000
G92 E0
G1 Z0.200 F7800.000
Did I missed to do something somewhere ?
Or could it be that the height of the plate is too close to the Z endstop ?
Thanks,
    Samuel
  • Do not run G32 S2 in start code. S2 means store to eeprom so you do not need it every time. If you really want to measure it always, just omit S2.
    Is your z probe also z end stop? If not, that is a big problem. You also need to disable ALWAYS_CHECK_ENDSTOPS since z probe might trigger preventing moves down when not measuring.
    Otherwise modify z probe height by your error and be happy.
  • Hi Repetier,
    Thanks for your hint, I will tried and post my comments if I still have some
