G or M Code for Flowrate?
is there a G or M Code that will control/vary the flow rate setting in Repetier Host? It would be a welcome function as it would allow users to change flow rates for different layers.
  • You can use M221 S<percent>
    Host also has this as slider if easy mode is disabled. Only requirement is that firmware understands it but nearly all do.
  • Cool!  THANK YOU!!!!!!!!
