Y coordinates out of range
Have installed Repetier Host into a new empty folder on Windows 10 machine.
Repetier Host V2.05, classic printer, Y Max = 200, not connected to printer
Slice with CuraEngine, generated g-code file Y coordinates are greater than Y max.
Example: "G1 X123.200 Y293.200 E3.88146"
Y cannot be greater than 200 but it is.
Cannot make this problem go away by changing any settings.
Please help.
Please help.
In host view check for the big dot on the bed. That is your origin and every line are 10mm. That way you can see if your settings are correct regarding bed position. Bed front should be 0 to start at ymin.
