Parking after print question
Is there a way to park the X and Y axis and ADD 5 or 10 mm to the Z axis after a print?
Looking in the Printer Settings in Repetier Host, I see the Park position, but would rather not park the z axis at 0 after the print as this could potentially drop the x axis gantry onto the newly printed part. I would much rather the Z axis move up and away from the print when it parks.
Sending the x and y axis to zero is good as it moved everything out of the way, but i am not sure about the Z axis parking.
  • G1 X0 Y0 F12000
    G91
    G1 Z10 F600
    G90
    as end gcode should do. Important is to switch to relative coordinates for z part. And adjust speeds to your printer.
